Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How to create this connection
4 REPLIES 4
nrm0504
296 Views, 4 Replies
Thile attached picture shows a tube column attaching to a tube beam ( canopy's) .
The connection we use are just welded inserts with hokes into the column and then bolted to the beam above.
How can I create this in advanced steel?
Any help would be appreciated
4 REPLIES 4
Sebastian_Eiche
in reply to: nrm0504
I believe you will need a custom connection here.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
nrm0504
in reply to: Sebastian_Eiche
I am brand new to advanced steel I managed to make the connections from column to concrete floor and from the beam to the wall with plates and anchors and all. Could you point me in the direction of a good resource about learning how to make custom connections?
Sebastian_Eiche
Try this:
https://youtu.be/dNqQzCd49M8
And this
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/sfdcarticles/sfdcarticles/Ad...
Sebastian Eiche
AleckGiles
Take a look at YouTube and search for Advance Steel IQ then look at episode 21. That is a lesson on Custom Connections.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
