Another way to bolt elements together, within the Advance Steel Tool Palette, under Custom connection, you can easily use :
"Bolts on beam" - Mostly used when you want to pick up beam first then another beam (any profile) or plate as second element. Do not require any change on the UCS position.
"Bolts/Anchors/Holes on plate" - Mostly used when you want to pick up plate at first then another plate or any profile as second element. Do not require any change on the UCS position.
Mechanical Design Drafter
If this information was helpful, please use the Accept as Solution function, this make it easier for other users.
