How to create a weld line?
asdemeter
asdemeter
The article that tells you how to do this refers to a "Connection Objects" panel, within "Objects".  There isn't one, and while there's a weld point command symbol, there isn't a weld line command symbol.  Anyone else find it yet?  I'm dying to use it.
Objects is the tab, Connection Objects is the area of the tab and in the upper right hand corner you will see the continuous weld.Capture99.PNG
asdemeter
When I get back to work tomorrow, I'll send you a screenshot. That's not where it is on 2019, and I haven't moved or customized anything.
Sebastian_Eiche
what @Anonymous is definitely correct so I think you maybe change something in your workspace.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
asdemeter
Not sure why my ribbon was so messed up, so I reinstalled it.  Now I have the objects tab.  I didn't touch anything, never changed a thing in the workspace, so I'm not sure why it wasn't like that.  But thanks, everyone!  I found it!  Finally...I can weld!  lol  So far, it's a bit of a struggle to figure it all out, but this program is going to change how I do my shop drawings here!
