Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How to Copy Saved custom Joint Connections in Library from 1 PC to another?
3 REPLIES 3
851 Views, 3 Replies
Hi All,
Changed over to a new PC so had to do a fresh install, is there any way to copy my saved custom joints in my previous library into my new library?
AC.
Hi All,
AC.
3 REPLIES 3
Sebastian_Eiche
Sebastian_Eiche
all saved joints are saved in the astorrules. So by copying this database, all you connection should be available.
You also copy the other database from this folder, to have all your settings like defaults:
C:\ProgramData\Autodesk\Advance Steel 2020\*installed language*\Steel\Data
I would delete the ldf files, then this should work without problems.
If you want exactly all the same from your old pc (bom list, drawing styles, palettes and so on) you could also copy the whole "Advance Steel folder" but as already wrote, delete the ldf files
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
in reply to: Sebastian_Eiche
Thanks for the reply Sebastian, this will be a great help.
AC
AC
desigan2015
Hi
1.Is it need to delete all the ldf files before the copy the files 2018 to 2020 .
2.I have to delete Astorrules-log.ldf this only or all the ldf files.
Hi
