How to change assembly name?
Priitl220
Priitl220
I would like to name my assemblies "column" and "beam" instead of IPE500 or whatever the main part is.
It seems something so obivous but I fail to do it.
Can anybody point me to the right direction?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
iwafb
I assume you are referring to the assembly name on the drawing border and not having your mark appear as "Column500"?
If so, you can edit the prototypes and use "ROLE" as a tag for the attribute you want to use to display the part name.
If instead you want the name to appear in the actual mark, you could try using the assembly prefix option in the naming (not sure what IPE refers to...)
Priitl220
IPE500 is the profile of main part (european).
Priitl220
I figured this out.
The paramater advance steel uses is "main part name".
I just need to go an change it to something else.
Where can I find the  "Main part name" option? TIA
Priitl220
You need to change the token used in template to other token.
http://www.graitec.com/en/FAQ_view.asp?FAQID=1038
