Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How to avoid the holes displaying as polygon on Advance Steel
3 REPLIES 3
robin_simonneau40
477 Views, 3 Replies
Hi everybody.
I am French, so I'll do my best to be understandable.
I'm new on Advance Steel and I don't know how to avoid the hole displaying as polygon on the model and drawing. As you can see on the first image, the hole tool does a polygon. When I do an extruding, if I use the presspull tool, it is okay, but I can't do that on profile. Moreover, when I do a drawing, it displayed as a polygon again, even the fillet, as you can see on the third image. At the top right of the plate, I have done a polygone with 50 sides to see the difference, and the contour is smoother on the drawing.
I searched a lot but I do not find anything, the "regen" command didn't work.
Can you please tell me how to get a smoother circle on the model and the drawing?
Thank a lot for your help in the whole forum, it is very useful.
Labels (2)
3 REPLIES 3
Hi @robin_simonneau40 ,
Does increasing this option in the Management Tools have any effect?
mick-CNF
in reply to: george1985
That is the number of bolts/holes when you add a circular arrangement.
Its the facet number, but don't go too high as CHS and round bar will look like a solid line in higher scale drawings.
If this information solves your problem please accept as a solution.
Yeah, it works well. Thanks a lot!
