Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How to add columns to the Bom lists?
1 REPLY 1
eyal.ch
310 Views, 1 Reply
eyal.ch
Hi All,
I make my drawings using the drawing process
How can I add the sheet no. and date for each part in the lists of the BOM.
Here is the template editor:
as I said I need to add a column that shows the sheet no. and date and Rev. for each part,
How can I do it?
Thank you.
Hi All,
How can I do it?
Thank you.
1 REPLY 1
Sebastian_Eiche
in reply to: eyal.ch
Sebastian_Eiche
for structured lists it's not possible to get the drawing number.
You could transfer the detailnumber with the modelbrowser for example to the Userattribute 1 and then use this token to show
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
