Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
How can folder a section in whole angle beam from 90 degree to 100 degree
7 REPLIES 7
Message 1 of 8
canhquy_ttt
255 Views, 7 Replies
Hi every one!
How can folder a section in whole angle beam from 90 degre to 100 degre like below image. Thank you so much!
7 REPLIES 7
Message 2 of 8
Dear,
       FOLDED PLATE
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 3 of 8
Thank you so much. But i need to create 1 object in clude two type of section (100 and 90 degree).
Message 4 of 8
Dear,
      Split the plates at line. after that, degree to be changed.
  Please to see attached drawing
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
Message 5 of 8
Thank you very much. I understood, but didn't solve the problem:
1. The angle of the steel bar when displayed is curved, not perpendicular like angle steel
2. Specifications of steel bars in the list are listed as "PL", not "L"
3. The volume is incorrect.
Message 6 of 8
Dear,
       To be changed that one.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
Message 7 of 8
i know, but it's not perpendicular at corner
Message 8 of 8
@canhquy_ttt
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
