Hot fix for model browser.
Rushiayarekar
Rushiayarekar
Hello Everybody,
I am using AS 2021 now, i have some problem with this model browser, i have pressed Assembly tab of this model browser window but it still not showing assembly properly. See image below this red circled items must be PL1. it still showing same even after i pressed every other tabs.
I have been told that there is hot fix for this. Can somebody help me to find out this hot fix?
robertwmerriman1
Hi @Rushiayarekar
You need to log into your autodesk account at manage.autodesk.com then click product updates and search for Advance Steel, you will see the 2021 hotfix
Or you can find the hotfix in your Autodesk Desktop app, again search Advance Steel
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
Rushiayarekar
Thank you, @robertwmerriman1
