Dear Expert,
In horizontal bracing gusset came in vertical.
My requirement is gusset plate in horizontal. How to get?
Solved by ArjunGaba. Go to Solution.
Solved by Dias_Antonio. Go to Solution.
Dear @S.MANICKAVASAGAM
I recommend remove the box connection and rotate-it 90 degrees, in order to suit your project.
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
@S.MANICKAVASAGAM Their is no macro for it in case of column to brace .. Since column system line in vertical gusset plate is coming vertical You have to apply manually this connection.
