Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
hole orientation different but same number
4 REPLIES 4
AntDrt
458 Views, 4 Replies
Hi everyone,
i've noticed a probelm with hole on folded plate see below:02.06.17 -reperage oblong.PNG
In the left:
bad direction for hole (not perpendicular with plate) Diameter Ø14 and oblong hole (sorry didn't find the english equivalent)
in the right:
Good orientation for hole (perpendicular).
AFTER numbering:
The 3 parts have the same assembly number (57 in my model) but they are different in real.
Is it a bug ? or maybe i have to reduce my tolerancies ? (0.6 in MT)
Antoine
AMG Fechoz
Serrurerie & Equipement Scénographique
www.amg-fechoz.com
4 REPLIES 4
múinteoir
in reply to: AntDrt
can you attach a sample drawing so i can take a look?
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
AntDrt
in reply to: múinteoir
Hi jonathan,
i've attached a part of my model.
Thanks in advance.
Antoine
AMG Fechoz
www.amg-fechoz.com
múinteoir
in reply to: AntDrt
If you change the 'tolerance for identical parts' in MT it will give separate numbers. I changed to 0.1 and it gives 3 separate numbers.
AntDrt
I've recreated another drawing with folded plate (identical dimensions, bolt in middle of flange)
And i've done a classic autocad rotate command, rotate by 20° and made a numbering. (Tolerance 0.6)
-> it gave me identical parts.
i've changed in the MT the tolerance to 0.2, renumbered the model
-> it gave me 2 parts
So it comes from the numbering tolerance, but 0.2 is a quite to much i think.
Thanks Jonathan.
PS: i've attached the second model.
Antoine
AMG Fechoz
www.amg-fechoz.com
