Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Hole definition_V2
2 REPLIES 2
tonilipovac
289 Views, 2 Replies
Hole definition_V2
what is differnece between hole definition and hole tolerance ( see attachment).
Thank you in advance.
2 REPLIES 2
mick-CNF
in reply to: tonilipovac
Hole definition is if you want a slot, tapped hole, countersunk hole etc.
If this information solves your problem please accept as a solution.
mick-CNF
If your bolts are in more than one beam/plate you can choose the definition for each individual item.
