I agree as far as the flexibility of Advance Steel as this point in time.
That is the major reason I do not to give up hope that the bugs will be fixed. I want to continue using the software.
Like you.... I can create pretty much create anything with this software and it is easy to do. I have lots of exposure to other parametric modeling programs (solid edge, solidworks etc.) and Advance Steel does very well with downline updates, copying, etc. They have a real winner as far as modeling goes.
I would be nice if Autodesk would give us some kind of a roadmap to what is going to be done to fix these issues in the near future.
There are no clear signals from Autodesk on the path they are taking as far as fixes.
As far as updates go.... it's the usual Autodesk strategy..... "give the users a couple of new minor features and slap a new year title onto the program...milk it for everything you can"
It appears that they are waffling in the wind at this point. The "updates" are not fixing any major longstanding bugs.
If the SQL database switch for the program is part of the path for fixing the longstanding bugs then let the users know what the path and timeline is for fixing the bugs that we all complain about.
After taking a breath we are still in the same place with only Autodesk's past performance with Advance Steel as an indicator of what will happen in the future with the program.
That is not a good sign IMO. I think most serious detailers in here are not thrilled about waiting 3-5yrs for the major fixes.
Tekla and SDS2 have the basics worked out.
Advance Steel's advantage with modeling and extra configurability will be erased by Tekla fairly soon (ex.Direct Modification, Tekla's Detail Manager w/new camera type objects just as a start)
Advance Steel's dev team needs to get in gear to be competitive. Riding on Revit's coat tails will not reduce the number of Tekla seats if they keep doing what they are doing.
Regards
Craig
