Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Hide Last Running Dimension Value
1 REPLY 1
joseph_hermogenes_042016
154 Views, 1 Reply
Hi everyone,
I need to hide the last running dimensions in the assembly drawing.
I tried changing the hide dimension option to 'last' in the detail styles, but it didn't work. I might be doing something wrong.
Is there a Management Tool setting I can turn off to hide it?
Any help would be much appreciated.
Joseph
1 REPLY 1
I think you will actually need to edit the dimension request in the Drawing Style. The point requests should only select the left of the main part system line or extreme or whatever and not all or both ends. Why would you select a point to dimension only to then say hide it in the dimension properties.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
