Hexagon Shaped Ladder Rung
suesLPLV6
Message 1 of 12
suesLPLV6
Is it possible to insert a hexagon shaped ladder rung?  Do I have to create a user profile for this?
Replies (11)
Message 2 of 12
Sebastian_Eiche
no this is not possible in the structural element.
I would use a round one, to have the points from the other beams, and then create the heaxagon and copy it to the place I want.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 3 of 12
mick-CNF
What are the hexagonal bars you want to use?
You should be able to add any profile and user profile to be a ladder rung.Screenshot (130).png
If this information solves your problem please accept as a solution.
Message 4 of 12
Sebastian_Eiche
I thought the cage should have a hexagon contour...if the bar should have this section: I'm not 100% sure, but I thought only round and flats are working.
Sebastian Eiche
Message 5 of 12
suesLPLV6
We're trying to use the hexagon as the ladder rung.  I did find the Atlas shape and can place it from line but I've been unable to use it through the ladder custom properties.
Message 6 of 12
suesLPLV6
I want to add the hex shaped rung by Atlas but it doesn't give me that option but all the others Atlas has appear.  I have tried adding it as a preferred size through Management Tools but it hasn't appeared and I have reloaded the setting so that's not it.
Message 7 of 12
Sebastian_Eiche
ok,
so you had to create the section and then had to add it to the cage ladder macro.
  • create the profile
  • open the management Tools and then the table editor--open the databases
  • have a look for the AstorProfiles and search your profile in the ProfileMasterTable and copy the name of the column: TYPENAMETEXT
  • this should something like "USR---the name you define"
  • after this you could add here:  RULE_CageLadder_LadderUserRung in the column DefaultProfile
This should work but i'm not sure, if I have a little bit time, I will try it.
Another way could be: open the profilemastertable of the astorProfiles and change the Subtypename from your created USR profile to "F" (which stand for Flat).. but this is also not testet from my side
Sebastian Eiche
Message 8 of 12
Sebastian_Eiche
Edit_ the last way by changing the subtypename is definitely working.
Sebastian Eiche
Message 9 of 12
mick-CNF
This is what you need to do, it works with any user profiles you create.
If you add the letter Q you can rotate the rung if you need to.
https://knowledge.autodesk.com/community/screencast/fad9d342-5a10-49cc-8e4b-6300dc986baf
Message 10 of 12
suesLPLV6
Sebastian you lost me?  I didn't create a user section it's available through Atlas shapes.  When I use the custom cage ladder it doesn't allow me to choose this specific Atlas shape.  I've tried added this to preferred profiles and so far it hasn't worked.
Message 11 of 12
Sebastian_Eiche
same procedur: search the Atlas and maybe change the subtypename to "D" for Round profiles, and then you could use it (in german it's not translated well 😃 ---"sechskantbalken"
Sebastian Eiche
Message 12 of 12
suesLPLV6
Thank you Mick that spelled it out.  I don't understand why this isn't  an available as a standard 1018 shape.  A hexagon for a ladder rung is standard practice in the U.S.  Now it appears correct but I need to manipulate the BOM /dwg to read correctly.
