As the attached screenshot, I tried to rename a user custom Astorprofile (not sub-profile). The table name and Key, Index were renamed, then in the management tools => Astorprofiles, I can see the new name, but the Preferred sizes => section class => Available classes still shows the old name and same as when I create a beam which only has old name to choose and shows no profiles(because I have already changed the name through SQL management studio).
What did I miss? Thanks for any help.
Michael
Michael
Solved by johnjmbennett. Go to Solution.
Solved by ChristianBlei. Go to Solution.
because shape classes are registed in the ProfilesMasterTable in AstorProfiles.mdf, you have to make equivalent adjustments- change the name- as well there.
HTH, Christian Blei
HTH, Christian Blei
Thank you, Christian. Could you please give more details? I need to edit under dbo.ProfileMasterTable some value in SQL Management Studio?
as @ChristianBlei said in the profilemastertable, which is within the Astorprofiles database, you need to access this DB and then under that table find the line relative to the user profile you added, then the ‘table name text’ Column, in that field , change the old name to match your new name of the table.
this old faq explains process To add in via access, it is Same for SQL.
tou can do this via the management tools table editor, to change the field value for the table name.
John Bennett
John Bennett
