- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a way to identify what grips a automatically generated dimension is snapping to?
I have attached a model of a simple launder box and the assembly drawing generated using the out of the box US drawing process suite: All SP / All MP.
In all 3 sections, there is an 1/8" dimension on the right side of the section. I can't figure out what grip the 1/8: dimensions are being derived from. How is the left side of each plate dimensioned correctly (or at least how I anticipate it should be) and the right going to a different grip when the two side plates are exactly the same?
As always, and help or insight is greatly appreciated.
Thank you.
