Hi All
I have started a new job and my new employer committed to Advance Steel prior to me starting. I am an experienced Tekla user and have done a 3 day training course with AS. The thing is, I am really struggling to figure out how to use AS. I can't do basic 'one-off' connections or simple things like putting a hole in a beam. No other detailers in the company to lean on either. Really struggling with the basics. Any advice would be greatly appreciated. Thanks D
*This topic's title has been edited by camilo.lemos for clarity
Solved by Jakub.Brozonowicz. Go to Solution.
Solved by chrisengg. Go to Solution.
There are lots of informative videos on Youtube and plenty of articles on the Advance Steel Knowledge Network. Try searching this forum or If you can be more specific in the areas you need help then I'm sure people on here will be more then happy to help.
Maybe ask your employer for more training as 3 days will only scratch the surface.
Hope that helps.
https://knowledge.autodesk.com/support/advance-steel
You can buy a reference book by Deepak Maini
He also has video lessons online which are activated once you buy the book and email him the code in the book
Pretty straight forward book for beginners
Hi Darren,
Please check an officially published list of available training resources.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
