- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone,
First off, it gets confusing.... drawing number, drawing name, part number, part name, assembly number, assembly name, file number, file name, sheet number, ect, ect.
Second, I am very new at customizing drawing processes, so please talk to me like I'm 5 years old!
I made a model and numbered it (beam assemblies B25, B34, B41 ect). I want my "file name" to match the "assembly name", that is I want files like B25.DWG, B34.DWG, B41.DWG. Maybe I should have done the "post numbering" method, but I have already released general arrangements which show these assembly names and don't want to renumber at this point.
So I made a new drawing process and found the Filename selector. I made the drawing name %PosNum.dwg
I went into my prototype (border) and changed the tag to POS_NUM and that works great, B25. Each beam assembly is on a separate DWG.
But when I use this drawing process, and get the "process properties" box, there is a place where you pick the starting "drawing number" and "drawing number increment". I don't want these in the file name. But no matter what I've tried, my file names have those drawing numbers attached to the end. I've tried the %flat(#) token in the filename selector, where # is number of spaces, even tried %flat(0) but still have those numbers attached to the end of the file name.
What am I doing wrong? Is %PosNum the same thing as POS_NUM?
Ron
