HAT No. 1:
Hi Devs,
Sometimes cap plates or base plates have beams running not at 90 degrees, and the default dimensions do not work:
Column dwg style, end plates from inside:
I see one other my suggestion is already implemented in AS, Thank you.
SP Plate dimensions-Improved Dimension Requests
Thank you.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
Link copied
