- Mute
- Permalink
- Report
Using A.S. 2023
I think I may almost be at my last issue with Advance Steel. I have read every thread I can find on this issue, nothing seems to work. I am able to get my Steel Sections hatched, but they are always Solid, regardless of the scale I set in the Table Editor. Is there something else that controls the scale or pattern? I have attached screen captures of all my settings. Help is appreciated...
While I am on this subject, assuming it can be solved: When you have a section through two or more parts, can the direction of the hatching be in apposing directions? (Standard Detailing Practices). See attachment "hatching". This would be the desired result.
AAG
Advance Design
Advance Design
