Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
HANG OFF RAIL PARTIALLY NOT VISiBLE
3 REPLIES 3
advandes
157 Views, 3 Replies
AS 2025
This is the first time I have every seen this where the hang off rail is partially not visible. See attached screen capture and file. Any help with this would be appreciated.
AAG
Advance Design
3 REPLIES 3
Flies-Eyes
in reply to: advandes
Does changing the Model Role change the output.  Could it be the model role is set to show as a line only?
mick-CNF
It doesn't like the curved rail to rail joint for some reason?
I presume this would work OK for 90 degree corners?
If this information solves your problem please accept as a solution.
advandes
in reply to: mick-CNF
Awesome! Thank you so much for that help. I don't know if I would have ever found that solution.
AAG
Advance Design
