Advance Steel Forum
Welcome to Autodeskā€™s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Handrail Issue
1 REPLY 1
201 Views, 1 Reply
Handrail Issue
I have a platform frame consisting of 150PFC members. The 2 parrallel north/south members are toes out. The east/west connecting member is toed in. When installed, the handrails for  the 2 north/south members do as they should and look fine and are centered on the PFC with platform mount stanchions, but the toed in east/west member handrail stanchions are positioned outside of the member. If i turn the end member toes out the same as the others the handrails install correctly.
I need to have this member toes in, what am i doing wrong?
1 REPLY 1
iwafb
You might have to upload a model or an image so we can see the problem.
However, you can always consider reducing the handrail panels. That is, instead of selecting all four beams (currently causing problems), you could do individual sections for each beam which would give you lots more control.
Cheers.
Technology Administrators
