Grids disappear in visual styles
a1iron
a1iron
I am having an issue where the grids in the model will show up on some Visual styles  and not on others. It is never the same though. Sometimes it will show on "2dwireframe" and not "shaded", other times it will show on "xray" but not "2dwireframe". I don't think it is a graphics card issue because all 3 computers here have different models of cards and we all have that problem. It seems to happen as models get bigger.
Is anybody else having this issue.
robertwmerriman1
Hi @a1iron
Is there any chance you could upload the model for us to have a look at, could you also confirm what version of Advance Steel you are running and what build?
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
Sebastian_Eiche
Maybe it's not directly the graphic card itself, but maybe the graphic card driver.
You could control the driver here: https://knowledge.autodesk.com/certified-graphics-hardware?id=18844534&siteID=123112
Often it's better to use the driver which is tested from Autodesk instead of a newer one from the producer
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
