Green pivot sphere when using a Space Mouse
DionRaph
DionRaph
Hi all!
I'm an Advance Steel user but I'm fairly certain that this applies to all, or a lot, of Autodesk products:
When I use a Space Mouse from 3Dconnexion in model space, there is a green pivot sphere (3Dorbit) when the mouse is in action. I would like to make it smaller, or I feel that it's not needed at all as by instinct you can "feel" where the pivot is as soon as you move a bit.
Is this 3Dconnexion driver related or there is something I can do in Autocad?
It's not a work-breaking situation but I do have to answer the question "what's this green dot every time you move around??" to all of my clients and partners every single time. It's more annoying than anything else ...
Thanks for your time!
Raph
Brock_Olly
Hi, this is the wrong forum to post this question but in autocad as far as I've seen there's no option to disable the green pivot point.
