Grating Connectors
Grating Connectors
dcubbedge
Message 1 of 8
Grating Connectors
dcubbedge
What is the point of having lines in the grating dialog box that deals with connectors if they can't be put on a list or BOM?
Is there an explanation somewhere how to make this work? Saying the connector is 'from database' does nothing different than saying it is 'variable.
I need a quantity to be seen on drawings in the BOM, and also in the lists.
Replies (7)
Message 2 of 8
bigcarl5000kg
Hi @dcubbedge ,
search in your BOM editor for Grating BOM and you will see, it's possible. Look in the settings for Report-Content for possible tokens:
And here a sample of the grating BOM:
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 3 of 8
dcubbedge
Thanks for this BigCarl!
Message 4 of 8
bigcarl5000kg
You are welcome @dcubbedge 😉
Message 5 of 8
maebingerEX3UQ
At first I thought I had found the solution here. But it doesn't work for me. Either I'm using the wrong template or I can't find the right settings. I have checked connectors and gratings in the report contents. But the connectors are not displayed in the list. I have no idea what I need to do.
Message 6 of 8
Sebastian_Eiche
in the first rwo, you will see the quantity of the grating itself. If you want to see the quantity of the gratingconnectors, you need to add a field for this.
So copy a field place it where you want to have it and change the field content to token as shown in the post
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 7 of 8
maebingerEX3UQ
Thank you Sebastian, this helps me very well.
I created an assembly list for gratings. The only missing is the total amount of the connectors. I can't find a way to integrate this.
Message 8 of 8
Sebastian_Eiche
You need to add in the groupfooter a token totalamount:
Sebastian Eiche
