When making a new grating clips BOM, I noticed that the token 'Grating Connector Quantity' is only reporting how many connectors are needed per panel, not how many of that connector are needed for the job total. And the 'Grating Connector Total Amount' token is reporting how many total connectors are needed, but not based off of the different types.
In this example, I have six panels that need the 1.5" Saddle, so the qty should be 24. There are two panels that need the T50 Clip (so 12), and one that needs the T58 clip. The total is correct at 42, but does not report how many of each one are needed.
Screenshot of the Template Editor (still working on the report header, taken from the bolt list).
under the BOM Template, which token is being used in the field content for the quantity, there are couple to try..
John Bennett
John Bennett
