Graphics card vs RAM
IanHopton1340
Message 1 of 50
IanHopton1340
I would like to speed up Advance Steel 2019.
My current setup is as follows.
Nvidia Quadro K2000 (2GB)
16GB RAM.
Windows 10 Pro
Most of my modelling is done with the 2d wireframe visual style
Current project has 16,000+ parts
What would be more beneficial?
More RAM on the motherboard
or
A Graphics more powerful graphics card e.g. Quadro P2000 (4GB)
What speed increase would I expect to get from each option?
Thanks in advance.
Replies (49)
Message 21 of 50
acbsdesign
A few extra bucks spent for custom built and extensively tested workstation by top company located in Texas would be washed away by the time wasted to make the things work, final result would be fast and stable workstation, not causing headache. Mine has already paid off just after few months of use, compared to my previous Xeon, 8700K is 25-30% faster. Models fly, updating details, printing of 300-500 dwgs is much faster.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 22 of 50
Adrian.Mangan
Hi Ilko
I'm dragging you back into this thread again, I am now just noticing you are saying the overclocked i7 is better than the 3.7 Xeon. I had ECC Ram and i7, discovered it was not compatible so just purchased the Xeon E-2176G, in your opinion will this be ok or would you have switch back the ram to non ECC and overclocked the i7.
Thank you for your time. Happy New Year
Message 23 of 50
acbsdesign
Happy New Year Adrian,
Keep the i7-8700K, overclock it, and purchase non-ECC ram, I just checked mine, it is non-ECC.
It is amazing what an overclocked processor does.
Message 24 of 50
Adrian.Mangan
Interesting maybe I should hold of on the Xeon, I agree with money saved and time spend not worth it, but I guess when I'm learning along the way it is all good.
Message 25 of 50
Adrian.Mangan
Happy New Year to you too Ilko
Thank you for your help, much appreciated.
Message 26 of 50
Adrian.Mangan
May need those specs after all Mark, might look into it, what is the ASRock board you have?
Message 27 of 50
Adrian.Mangan
What cooler would you recommend?
Message 28 of 50
markhubrich
Message 29 of 50
markhubrich
If I were to buy one right now it would be this model...
https://www.newegg.com/Product/Product.aspx?Item=9SIAHY38GH1187
...and fix the kiss export issues.
Message 30 of 50
Adrian.Mangan
This is getting interesting, haha, I like the board, maybe I'll try overclock the i7 i have now before the Xeon gets here, 30 day return option.
Message 31 of 50
Adrian.Mangan
is there any type of ram you recommend or is it much the same, Hynix?
Message 32 of 50
markhubrich
Cooling, Cooling, Cooling 😄 Please use extreme caution 🙂 Cooling, Cooling Cooling
Message 33 of 50
acbsdesign
Tried to take a picture of it, couldn't figure out who is manufacturer, Boxx installed their cover. Motherboard is Z370 Taichi.
Message 34 of 50
markhubrich
read this...
http://asrock.pc.cdn.bitgravity.com/Manual/Z370%20Taichi.pdf
Message 35 of 50
Adrian.Mangan
mmm, you have same motherboard, interesting
Message 36 of 50
Kirk_bailey
2d Wireframe.. There lies your problem. So, even though it's a simple view style, the number of extra lines the cpu has to render will slow things immensely! I'd suggest using conceptual instead, for it has less lines it needs to render out. Wireframe is great if you have only a few objects displayed at a time. otherwise, it's really processor intensive.
Also, AMD ryzen 5-7 series is a lot cheaper & outperforms anything intel can provide right now, in my opinion.
Message 37 of 50
Sebastian_Eiche
I'm not sure how often I told this on my trainings 😄 , therefore shortcuts and toogle switch are great to switch between these visual styles.
But maybe according to this thread, if you buy a video card and processor for a lot money, it should work... up to a very big model. But I had to learn the last years, that this is not a warranty for a good working system.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 38 of 50
markhubrich
Hey @Sebastian_Eiche you just caught my attention with
I've been meaning to figure out how to do this with my drawing units between architectural and Decimal for years.  Sorry for hijacking 😄 If it isn't too much trouble would you mind PM'ing me a link to some content regarding this please?
Message 39 of 50
acbsdesign
This is my set-up for 2D wireframe, no any issues with larger models, including bridge work:
Message 40 of 50
Adrian.Mangan
mmm, mine is the same but when using 2d wireframe large (300,000lbs) model is jerky, (model takes about 6 seconds to regen) a lot better in wireframe when using the GPU. So from what I have learned in the past week you overclocking is probably doing this as 2d wireframe is relying on CPU.
Starting a 5 story building this week so I guess I'll find out the hard way.
Thanks again Ilko for your time and help.
