I'm getting 'ghost" objects in my IFC export. AS you'll see in the screenshot the AS model shows one stair in its proper position. The IFC viewer shows 2 stairs, one in the creation position prior to being moved and rotated. I have tried audits and purging with no success. What is going on?
Solved by Sebastian_Eiche. Go to Solution.
could you upload your model? Only by having a look on pics, it's not possible to find the problem
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
@Sebastian_Eiche Here you go ... Jakub with Autodesk has sent it to "The Developers" so we'll see what they say
you have a frozen layer called "existing Steel" ...unfreeze it and voila...
Sebastian Eiche
@Sebastian_Eiche WOW!! I feel like a true idiot now! Give me the "Doorknob award"!
I really don't know how they got on that layer, or become frozen.
Thanks Sebastian!
no problem, if all problems could be solved like this, I think we all will be happy 😃
Sebastian Eiche
