- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using advance steel version 2023.
I have created new GA drawing style through drawing style manager as per my standard, by using this new style i have created entire structure GA elevation drawing.
I have arranged all the Tags and Dimension on it. those drawing are almost in final touch.
during the update in to the drawing file, i have seen the framing member line are displayed as EXACT member instead of Standard shape
after created and updated all the structure GA elevation drawing i have made minor modification in the same Drawing style and saved it.
but when I use Force update in Document manager then my new update are not reflating in drawing the drawing look like old setting.
should i have to re-create all the view by using the new drawing setting or is there any another way to update the prepared drawing view?
Thank you,
Mayur Prajapati.
