Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Force AS to draw Front, Top, and Bottom Views
3 REPLIES 3
bjur
1664 Views, 3 Replies
How do I get Advance Steel to draw the Front, Top, and Bottom, views of a beam or column instead of automatically choosing which ones get drawn?  For many beams with studs, AS will only draw the front view.  Same goes with columns.  I know I can manually double click on the view and tell it to turn the view state to ON, but I can't seam to find where this setting can be made in the drawings styles manager.
3 REPLIES 3
alickomay
in reply to: bjur
yer uil need to play about with seting in drawing proces maneger and drawing style maneger  in the output tab
its prity complicated and i was unabil to find any documention to help i asked gritec about it once and thay sed it was beond the scope of the emil suport thing we pay for and i would have to got for a 1-2 day traning cours on customizing that stuff
so spent a few days  playing trial and eror intill i got sumet like wot i wonted
hopfuly autodesk care more for docmention then graitec did
Emanuel.Nestor
in reply to: bjur
Hello bjur,
One solution is to deactivate the behavior of automatic views for all drawings.
In this way you will get all the views from the Drawing Style.
To do that:
  • Open Management Tool
  • Go to page Defaults
  • Open category Drawing-General - General
  • Search and deactivate the option "Use the "necessary views" verifications"
  • Open a new session of Advance Steel and generate the drawing again
I hope this helps
Emy
Emy Nestor
Emanuel.Nestor
in reply to: bjur
Another way is to configure the cases when you want to have always the view.
For example: you may want to always have the "Upper view" for columns.
In this case, add a new rule in the Necessary view wizard, like in the attached picture.
  • Open "Necessary view wizard"
             Ribbon --> Output --> Document Manager panel --> Necessary View Wizard
  • Select a category where you want to add it: Advance, User
  • Add a new rule and select:
             View type: Upper view
             Model Object: Column, function
             Rule: Always show
Emy
Emy Nestor
Technology Administrators
