Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Folded plate drawing output
1 REPLY 1
faijanuddinshaikh
116 Views, 1 Reply
faijanuddinshaikh
Is this kind of output possible from advance steel drawing styles? after some customization in styles maybe? or my only solution is to do this manually? The fascia has many folds so can't work with a folded beam I read.
Current output -
Expected output -
Current output -
Expected output -
1 REPLY 1
AleckGiles
The flat pattern is the TOP view of the plate. You can add right, left, front or rear views to the drawing style as desired but it won't do automatic sections on a part drawing.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
LinkedIn
