Fly Brace - Single Side - bolt size adjustment
I'm having trouble adjusting the bolt size for a fly brace on just one side of the rafter.
As per the attached picture the section to change the bolt size is locked ?
TIA
Cheers
sampie
Here is what you do:
1. Go to the "Sleeve" tab
2. Enable the Sleeve (this is just temporary)
3. Now go to the "Bolts" tab and change the size
4. Now go back to the "Sleeve" tab and disable the sleeve
Hope it helps!
Kind Regards,
Sampie
_______________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
youtube.com/prokonbuild
