Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
find a secondary connections of a primary connection
5 REPLIES 5
alazo8PUCV
128 Views, 5 Replies
Hi. Is there any way to find all the secondary connections of the primary connection?
5 REPLIES 5
Yould insert a name and then set a list for the primary or secondary conn of this name.
create a querry for joints with the name.
first one for primary:
is primary and the name (red color in my pic):
for secondary (green color in my pic):
result:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Perfect, that is what I was looking for. Thank you
Your solution is very good.
How did you add the colors to the boxes? Was it just to illustrate the solution or was it done automatically?
the color could be set n the general tab of the dialog
Sebastian Eiche
Thanks for the reply.
