Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Extrude Text Through Channel.
6 REPLIES 6
Adrian.Mangan
1152 Views, 6 Replies
Adrian.Mangan
Hi everyone
I'm looking to cut writing into a channel which will be part of a canopy over doorway with Company name in it.
Is there a way I can explode text (I know this does not work) and turn it into a polyline to cut that contour into the channel.
I understand I can draw the letters a polylines was just hoping there was a way to do it with written text.
Also it would be useful for etching numbers on plates etc.
Thank you
Hi everyone
Thank you
6 REPLIES 6
muleman1
in reply to: Adrian.Mangan
muleman1
try this screen cast. they be better way, but this is way we do it...
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
johnjmbennett
Try express tools, think they are still in 2018 autocad, found references to them still.
installs a separate series of tools aimed at autocad functions.
to load goto programe and features , change , look for the additional items to install.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoC...
there used to be a command to explode the text to give a pline outline if I recall correctly.
you may have to redo some of the curves in text characters to make them work with the ploygon contour feature in AS to cut out the profile. May have to fillet internal corners to allow to burn/ profile cut radius.
In AS look on AS palette,  features - polygon contour.
Worked a few years back on a job we had, hopefully still now also.
think there are few FAQ out there on express tools.
John Bennett
John Bennett
muleman1
in reply to: johnjmbennett
muleman1
if express tools isnt in your ribbon tabs, just type,   express tools  in command line...you may have to switch workspace to drafting...not sure
Adrian.Mangan
Thanks so much for replies, looking forward to pursuing this after dinner.
Much appreciated
Much appreciated
mahmoudmo7.zaki
in reply to: muleman1
mahmoudmo7.zaki
Community Visitor
Community Visitor
Thanks a lot for your efforts , that was very useful but can you please tell us how did you wrote the text on the beam from the beginning.
muleman1
in reply to: mahmoudmo7.zaki
muleman1
We just choose any text tool, then use express tool bar to explode text into polylines.  watch the screencast closely, you can see how
