Hey,
i have a problem with the export to dxf function.
Every folded plate which i will export is two times in the dxf file.
The first one is without any holes....
and the second one is exactly like i need it.
The problem is that i have to open now every of my hundred dxf file and delete the first one,
becaus with my machine program i can not do this.
Is there a way to turn off this function?
Thanks a lot
Solved by Sebastian_Eiche. Go to Solution.
in the DXF in above and below is everytime showed up, this is important for example for threaded holes to know from, which side it should be drilled.
If only need the DXF with holes and no connected parts, you could create a detail style for this maybe a process for all plates 1:1 and then explode the details and save as DXF.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
