Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
exact countour on isolated panel
5 REPLIES 5
javiervega10
293 Views, 5 Replies
javiervega10
hello.
How can I make the cladding profile with thickness, as an isolated panel, be represented in the model and in the 2D drawings they be represented with the exact countour?
Any profile insulated type always appears rectangular in the model and in the 2D drawing
the flat cladding profiles, if they appear with the exact contour
hello.
5 REPLIES 5
Flies-Eyes
in reply to: javiervega10
Flies-Eyes
That is an interesting question.  I have a custom insulated panel profile that I need to add this week myself.  It has been quite a few years since I looked at this topic so I will need to refresh my memory.  I don't think creating a profile with thickness is the issue, I just can't recall if cladding profiles have an Exact and Basic profile function like beam profiles have.
I will keep you posted on how I go with my task this week.
javiervega10
in reply to: Flies-Eyes
javiervega10
I already made a custom cladding profile, but it also appears in a rectangle.
maybe I made the wrong profile 
K_Kubat
K_Kubat
If I only go by the color of your contours, I suspect that they were created on the wrong layer, but the layer can be changed manually and cannot be checked without DWG.
By default, the detailed contour must be on the outside layer "AS_ExactOuterSection" and inside "AS_ExactInnerSection", the layers "AS_OuterSection" and "AS_InnerSection" are for the standard representation.
The corresponding style must be set to (exact) in the plan output.
AleckGiles
AleckGiles
I have done a full webinar explaining how to use cladding and add your own cladding sections to the system. You can watch it on YouTube here.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
LinkedIn
mick-CNF
mick-CNF
Insulated Cladding
If this information solves your problem please accept as a solution.
Insulated Cladding
