- Mute
- Permalink
- Report
Hi folks,
a quick one today : Where can I change the default dimensions of a baseplate in a macro?
I mean, default size is HUGE... nothing to worry about but it's kind of annoying when using again and again the same weirdly coded macro...
As example, Miscellaneous>End plate with bolts is this size per default :
I can't remember which one but there is some others macro that the default size are completely out of logic dimensions.
It is probably hard coded like that but I'm asking if someone have a cue.
Mechanical Design Drafter
If this information was helpful, please use the Accept as Solution function, this make it easier for other users.
