DXF files for folded beam
Mickael.B.Parker
Mickael.B.Parker
Hello everyone,
1. I would like to add the single part mark on the folded beam as it does for the plate
Folded beam:
Plate:
2. I also would like to remove the one on top (without holes in that case):
Thank's
crydee-AG2
The part number should appear on the DXf for a beam exactly the same as it does for a plate. Of course, the beam is generally a lot bigger so the fixed-size text will appear much smaller in relation to the beam.
You cannot suppress the second view of a beam; that is only possible for plates. A DXF is only another AutoCAD format so you can always open and edit the file manually.
Aleck Giles,
LinkedIn
Autodesk Certified Instructor - Gold
Julio_Soto
so you can't suppress the 2nd view, what exactly is the second view of? The opposite side? I would've thought that view would be mirror but it just looked like a copy
Julio_Soto
I found the solution in a seperate post, also from @crydee-AG2
https://forums.autodesk.com/t5/advance-steel-forum/two-views-in-dxf-files/m-p/9227004/highlight/true...
If I use DXF(Plates) not DXF(All) on the unfolded beam, I wont get the second view.
