Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
drawing style to include 3D solids in GA drawings
5 REPLIES 5
1678 Views, 5 Replies
I realize AS software is "geared" toward detail/fabrication drawings, however we are using AS to do our engineering/design drawings.
Often I will have to use basic 3D solids to show my geometry. Especially when working with foundations (as AS has limited concrete commands) Example: my turn down edge for a foundation is a 3D solid (attached)
I have had to create/modify the GA drawings styles to show things the way I want them to be presented. HOWEVER, I cannot get the 3D solids to show up in my GA plan or section cuts. Below is a screen shot of my foundation plan drawing style. I cannot figure out what I need to add/change to my object presentation to get 3D solids to show up. Any tips?  (attached)drawing styledrawing style3d solids3d solids
5 REPLIES 5
alickomay
3d solid as the thing u get from  extended modeling/modeling
i just triyd make a ga with "3d view-selected no labels"
and i can see solids
ther shown in 2d wire view style  but  all drawing are
alickomay
attached object presention  screen shot
in reply to: alickomay
Thank you for looking into this. I can see the 3D solids in a 3D view but I am not able to see the solids represented in my cut views (Plan or Sections views)
Can you get those same objects to show up in a plan?
alickomay
yer got it showing in plan setation all
but i had to add  "add.acis solids"
i think u can all so add all   but that probily add stuff u dont wont
alickomay
there is a hierarky to theys things  if the is sum think in line 5 that turns solids off sum think in line 10 will nerver turn it on
see pic
this is wot as thiks is add acis solid
have lok in selected model objects off other lines above make shore nun could be solid
solid is not only solid   , for  instens "all" will all so  be soild and every thing els
beam is flat,  colums, beam , tube ...
Technology Administrators
