DRAWING STYLE MANAGER TEMPLATE
In User created Drawing styles, I have copies of View names. I get an extra copy when I import a drawing style. How do you delete the extra copies?
Kirk_bailey
Kudo's for asking the real questions here!
Advance Steel creates copies of the Data used to create User Drawing Styles and in order to prevent this, you must manually rename each copied version to suit the drawing style. you can call it anything you want so long as you rename it to something else.
This is very time consuming if you have a lot of user drawing styles & if you don't do this, eventually your database will fill up & cause redundancy errors.
Advance Steel does provide an Audit tool, however i don't think anyone is convinced that it actually does anything.  You can try it, just export your user drawing styles first(incase it messes them up and deems the useless)
