Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Drawing Revision Index
5 REPLIES 5
ATCOSTEEL
638 Views, 5 Replies
Hi Every oNe,
Happy New Year.
I was wondering that if is there any easy way to create the drawing register/ revision index with advance steel or not?
5 REPLIES 5
Sebastian_Eiche
in reply to: ATCOSTEEL
Please don't misunderstand me, but Advance Steel has an online help. If you have a look for Revision, you will find many information about it. You could create rev index in the document manager and then the changed objects will get a rev.cloud and the rev.index table will be created.
In Advance Steel you could also create an external drawing list with information about the revision index
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
ATCOSTEEL
in reply to: Sebastian_Eiche
Thanks for your response.
Yes i do know about document manager and setting up the revision in that which will reflate the revision accordingly in 2d shop drawing.
But what we been asked by  client is to give them the drawing index which saw the revision and date that it get revised.
i have attached image what we want.
Sebastian_Eiche
What version do you have installed? If you open the bom list palette, there should be a category for drawing lists. If you want to have a look like your picture, you had to copy an existing template and change it as you want to have it.
Sebastian Eiche
ATCOSTEEL
i have installed AS2021.
Sebastian_Eiche
as I wrote, in the drawing list category you should find it, and it looks in original like this:
Sebastian Eiche
