Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Drawing Process
6 REPLIES 6
399 Views, 6 Replies
Drawing Process
How to create multiple beam drawings from one selection in the model.
I want to stop all the beams from being on one sheet, Want one beam per sheet.
I can't seem to find the answer to this anywhere....
Thank you.
6 REPLIES 6
muleman1
maybe try one of these
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
in reply to: muleman1
Hi Muleman1,
Thanks for your response, but I have no idea what your trying to show me?
You will have to be more specific.
Cheers.
DumitruBerteanu
muleman1 showed in the pictures above a set of processes that allow you to create drawings for all beams, in an one per sheet system.
You obtain all the beams on one sheet in your case because you are using a drawing style, which doesn't have the option to automatically split the drawings on multiple sheets.
Those processes can be found in the Drawing Process palette, accessible from the "Output" ribbon tab.
Processes have two types of "Selections " : All and Selection. The "All" processes will not request any selection, and it will just detail all objects that match its criteria (e.g. an Assembly Beam process will take all assemblies where the main part is a beam and detail them). The "Selected" processes can perform the detailing on a pre-selection done by you in the model. You need to do this selection always before applying the process, otherwise the process will do nothing.
Dumitru Berteanu
Product Owner
johnjmbennett
This is controlled via the drawing process, these are found inside the drawing process manager, there maybe some existing ones in place, which in the user part of that manager you can adjust copy.
For a single assembly on single sheet, the file name selector needs to have opition set to move onto the next assembly/main part , you will find this under the file name selector.
There are some nice videos on YouTube explain drawing process creation and methods to adjust etc.
https://m.youtube.com/watch?v=K4JmYyGhf4U
John Bennett
in reply to: johnjmbennett
Thanks for your help guys, I'm must be missing a step, did all what you said and watch the you tube clip and same result every time.
muleman1
@Anonymous we are far from expert and struggle too. see if this screencast helps....
Technology Administrators
