Drawing process manager
S.MANICKAVASAGAM
S.MANICKAVASAGAM
Dear expert,
             I created one beam assembly drawing with parts from drawing process manager. After that, the model modified some parts added /deleted and then numbering process done. now, the updated drawing opened. here, drawing list, drawing detail updated from comment. But, how to get the newly added single part detail and remove the deleted single part. please clarify.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
dusanduckinoski996
Can you show some sc?
AleckGiles
Doesn't Force Update or Update revision from Document Manager work? They are the normal way to get any drawing to come up to date. You can use those command seven on drawings in the Up-To-Date folder; you don't have to have them in the Update Required folder although it ought to be in there by now.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
