Drawing BOM Templates - Custom Assembly list
varna_r
Observer Observer
varna_r
Observer
Observer
I am trying to create my custom BOM Template dwg for Assembly list from scratch. Here in this forum I found and read some useful information and utilities for how to customize from existing drawing list template. I learned and tried a lot from this :
FAQ: How to customize a BOM on drawing template?
Assembly list in drawings like this is something essential in GA drawings in the projects in many countries.
All starting from Output tab; BOM on drawing; Creating List Fields, Group manager,  Group selection, List sorting and content and so on....     But the information of creating such tempaltes is not enough detailed to the end - it is not enough full. Is there more full and detailed information which token how works, how to use List Sorting and content.
How is needed to look like:
About 70 - 80 % of my created custom assembly list now works properly:
Stil can not make proper last column and to have right Total weight in the end.
Custom BOM - Assembly list - dwg
Sebastian_Eiche
I would use a new column with a Formular: quantity x weight
Here is a good thread for a customized template:
https://forums.autodesk.com/t5/advance-steel-forum/bom-on-drawing-formula/td-p/8841994
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
varna_r
Observer
Observer
Thank you fot the advice ! ! !
I  didn't know about "Formula" Token. I read all in suggested tread, tried some of the ideas  but stil not success for mine list - I want to show only assemblies - not SP
Is there any explanation for the "List Sorting and Contet  - Source and Result and the arrows UP and DOWN.  I think the problem is in this things .
Sebastian_Eiche
If you just want to see mp, just use a structured list and set all fields of the details area to 'not show' in the advance properties
Sebastian Eiche
