Document Manager Deleting Drawings
mitchell8TKBM
Message 1 of 10
mitchell8TKBM
My Document manager has started to delete my drawings after forcing an update. I try to re-register the drawing with the model but after I force update it is deleted again. I do not understand why it deleted in the first place and also why it keeps deleting after re-registering the drawing with the model.
This has started happening on multiple models I have created.
Please see screencast I have uploaded.
Accepted solutions (3)
Replies (9)
Message 2 of 10
robertwmerriman2
Hi @mitchell8TKBM
I cant see the screeencast, you you share the link for the screencast please
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
Message 3 of 10
mitchell8TKBM
https://knowledge.autodesk.com/search-result/caas/screencast/Main/Details/1c52de94-319d-4936-87d8-7a...
I keep getting errors when trying to insert it through my screencasts, Hopefully this link works.
Message 4 of 10
robertwmerriman2
Hi @mitchell8TKBM
Yeah ive always had trouble with direct uploads, I just use the links these days.
That is odd behaviour, there are a couple of things to try
1. Can you check your Advance Steel build windows permissions
Close Advance Steel, then go to C/ProgramData/Autodesk/AdvanceSteel Version
Click on your build (example below 2021 GBR build) then right click properties
Go to security
For each group / user (Except CREATOR OWNER) make sure full control and modify are ticked
Open Advance Steel and try the drawings again
2. Are your models & drawings saved on a network / cloud location
If so please take a copy onto your C drive and test from there to ensure these are not the problem
Message 5 of 10
Jonathan3891
I've had so many issues with document manager in the past that I've stopped using it all together, except for renaming drawings. That is the ONLY thing I use document manager for.
I open drawings individually and update them. I have a lisp file that has been posted in the custom commands post that will allow you to select multiple views and update them to make it easier.
Jonathan Norton
Blog | Linkedin
Message 6 of 10
mitchell8TKBM
I changed my permission settings as you mentioned and it didn't make a difference. I then copied the drawing from the server to my local drive and that seems to be working. Is there something I can change to allow me to work directly off the server?
Thanks a lot for your help.
Message 7 of 10
robertwmerriman2
Hi @mitchell8TKBM
Im afraid I dont have any experience with network setup.
I would show the behaviour of Advance Steel to your IT team when on your C drive, then show them the behaviour of Advance Steel on the network. Im sure they will be able to change some permissions or some network settings so Advance Steel runs as expected.
Message 8 of 10
mitchell8TKBM
Thanks for your help. I will get my IT team to look further into this. Cheers
Message 9 of 10
Sebastian_Eiche
maybe additional to this:
we often have this issue with customers and we encounter problem with mapped drives for example with onedrive and sometimes the same problem for the situation if the network drive is backupped conesquently to another drive. So the situation is the following: AS want to update the detail and in the same moment, the backup tool use the file to save it--> the file will be deleted sometimes.
Another issue: have a look for the length of your filename...windows is limited for 256 characters 😉
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 10 of 10
mitchell8TKBM
This is exactly the problem. Our dropbox is backing up the files on the mapped drive. The files are not deleting when I pause the dropbox syncing. Is there a workaround to this so that I can continue to work on the mapped drive while syncing with dropbox?
