Document Manager - can't assign new drawing number; the drawing number already exists
radic_dominik
radic_dominik
Greetings experts,
I have trouble adding new numbers to generated drawings. How the hell is not possible for the first drawing to use number 1 when I didn't use it in the current model (scrnshot 1 and 2)? This also applies to other drawings, where I can't use numbers 1 to 6, only from 7 and above are free to apply. Is it possible it is related to another dwg model which was first numbered from 1 to 6 (scrnshot 3)? Don't have any rational explanation.
Any suggestions?
Wrong number (scrnshot 1)
The number I need (scrnshot 2)
Another dwg model which was first numbered correctly (scrnshot 3)
Sebastian_Eiche
There's a difference between filename and drawing number.
If you create a detail drawing, there's an internal counter which define the file itself. This internal drawingnumber could only be changed by the contextmenu in the document manager
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
