Hi All,
I try to make a connection made of 2 angles and 2 RHS profiles
like this:
I set the UCS so the Z will be trough the drilling and when I tried to make another connection like this
it made the holes only through the angles and the RHS left without holes, why?
how to ensure that the drilling will be for the angles and the RHS profiles.
this is what I got when I tried to make the same connection for the other side of the frame:
in the angles there are holes
but in the profiles the holes are missing, why ? and how to fix it
Hi All,
like this:
Solved by mick-CNF. Go to Solution.
The holes are in the SHS, change the presentation to standard.
