Display Objects
Display Objects
bageseabraham
Display Objects
bageseabraham
Hi Everyone,
Does anyone have an issue with "display objects connected in shop" macro (AS Tool Palette --> Selection--> Display objects connected in shop)?
If I am selecting the welded assembly, it does not turn to red colour (AS Default Colour). I can see that it is working by using " Select all marked object" macro.
Please share some ideas to fix this issue.
Abraham
Could you attach the file that you were using when you encountered the issue?
Sebastian_Eiche
the marking method is always the same, so the question is:
Does other marking work like clash check? or the result of a querry?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
bageseabraham
Please find the attached screencast & model.
Abraham
Sebastian_Eiche
it's working on my side. I would try to use the repair command of the windows uninstall feature. Maybe there's something wrong in any file of your installation.
Sebastian Eiche
I had the same issue when using your objects. However when I created my own plate with a welded connection the marking worked fine. I think there could be an issue with settings on your end.
