Is there a way to get the dimension style to dimension to the centre of a beam flange and not the toes of the flange in a top or bottom view?
John Stewart.
Solved by acbsdesign. Go to Solution.
@Anonymous wrote:Is there a way to get the dimension style to dimension to the centre of a beam flange and not the toes of the flange in a top or bottom view?
John Stewart.
Hi John,
It is possible.
1. Make representation for bottom view to include system line (Visible Hidden System)
2. Per screenshot below, I had separated these dimensions into top and bottom, if holes are in the left half of the beam, dimensions to appear to the left etc.
Dimensions will be Holes Linear top V front....
And the second line would be Ref. MP System, All along MP Y. Left end would be TOP of MP, right end would be BOTTOM of MP.
Mine 1.25" dim's did not combine, I moved one of them to be aligned with the other.
HTH.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
